scart to component/rgb
Discussion in 'Plasma TVs Forum' started by dragon1, Jun 9, 2003.
  1. dragon1
    dragon1
    can anybody point me in the right direction please, I have a Panny 50" that has a Scart plug on the end ( the Plasma scart lead is chased into the wall , through the roof and down the other side of the room ) so i am kinda stuck with it !
    Is there a device I can connect this Scart plug into and connect to my Denon amp's rgb/component outputs, thus using more secure connections than scart ?
  2. briandzo
    briandzo
    Dec 12, 2002
    373
    19
    Newbury , Berkshire
    www.maplin.co.uk
    part number LG99H SCART Coupler
    this device seems to couple scart leads together
    therfore goto this place
    And AVsales
    http://av-sales.com/html/cabling.html
    Scart plug to 3 RCA/phono RGB ( No Audio )
    2m length £41.793m length £50.355m length £56.8610m length £75.9915m length £95.1020m length £114.2330m length £150.13
    for your scart to YUV breakout cable.
  3. symanski
    symanski
    Jun 20, 2002
    874
    Scotland
    +8
    As an engineer, I'd have added another ten leads for future use. And then had trunking put in just to be sure if I needed to add more....
    briandzo's advice seems sound. Just ensure that you've got the right signals going to your screen to get the best out of each of your sources.
    All the best,
    Dr John Sim.
