captaindobie
Established Member
I have recently purchased the Sharp LC32GA5 which i am very happy with.
I currently run every source that i have into the SCART (RGB) socket on the TV via a SCART switch box.
(None of which produce a progressive output)
However, would i find any impovement in running SCART (RGB out) into the COMPONENT inputs on this TV? (via a SCART to COMPONENT cable)
In addition, would SCART to the Analogue PC input (D-SUB 15 pin RGB) produce even better results again?
Worth doing?
If so, where is the best place online to buy the necessary cables?
(Keene Electronics?)
Worth doing?
