SCART to Component cable
Discussion in 'Cables & Switches' started by Taylorg, Dec 16, 2004.
  1. Taylorg
    Taylorg
    Dec 6, 2004
    89
    I'm after some help with regards what cables to buy to hook up my Sony 735 DVD player to my new Denon AVR-3805.
    I have seen the PGV372 from http://www.profigold.com but I'm not sure if that is what I need.
    Thanks for your help
    Grant
  2. SamirP
    SamirP
    Apr 28, 2003
    1,232
    South Of The River
    +32
    Hi Grant
    I think that only the Arcam 300 will accept an RGB scart signal via it's component input.
    You options would be:
    1, buy a JS tech RGB to Component converter
    2, just use the s-video output on your dvd player and let the 3805 upconvert to signal to component.
  3. Reiner
    Reiner
    Jul 16, 2000
    3,315
    61
    Germany
    +13
    You can switch RGB via component connectors as long as the amp also switches one of the composite inputs (required for the sync) at the same time.
    Thus you need two adaptor cables Scart to RGB + composite (DVD to amp and amp to TV).
  4. Taylorg
    Taylorg
    Dec 6, 2004
    89
    Sorry I've been away for a few days.
    Thanks very much for your replies.
    Grant
