scart to component+audio do they exist?
Discussion in 'Cables & Switches' started by jonesey68, Aug 26, 2005.
  1. jonesey68
    jonesey68
    Aug 26, 2005
    41
    I have a sony freeview tuner with scart connector and a hitachi 17LD4000 LCD TV with component connectors, audio L+R and S-video inputs, I am using the supplied scart to composite lead but wondered if I could improve the picture, any advice would be appreciated
  2. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    23,805
    The Borders
    +2,471
    jonesey68
    Your Freeview Tuner is most likely to offer you Composite or RGB video (+ stereo audio) from its SCART Output (you have to go into the set-up menu of the Freeview box to select RGB Out).
    The RGB Output produces a much sharper and more detailed image than Composite Out.
    If your TV only has S-Video and Component (YUV) Video Inputs (no SCART?) then you require an active Converter box to convert the RGB source signal into S-Video (good) or YUV (better).
    JS Technology produce a range of suitable converter box's and you'll find plenty of positive feedback on AVForums from folk who have installed the JS Technology kit.
    See http://www.js-technology.com/index.php?cPath=22&osCsid=3ef368645ff1ebe18b65e7081cc181b4
    Best regards
    Joe
  3. petrolhead
    petrolhead
    Mar 29, 2002
    4,477
    71
    Newcastle
    +81
  4. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    23,805
    The Borders
    +2,471
    Hello Petrolhead
    A cable with a SCART on one end and 3 RCA on the other relies on the Source to Output YUV Component not RGB - some DVD players and the odd Freeview have the option of YUV on SCART.
    If your Source Outputs RGB on SCART you will require a converter to convert RGB to YUV if you want to connect the Source to a 'Component' Input.
    Best regards
    Joe
  5. petrolhead
    petrolhead
    Mar 29, 2002
    4,477
    71
    Newcastle
    +81
    Thanks for that Joe
    Now understand
