james_19742000
Established Member
Hi all,
I am soon upgrading all my AV bits, I am buying a new DVd player and also an AV receiver, my plan is to run componant from DVd to componant input on the Receiver, then also a cable from my Sky box to the receiver, then one cable from receiver to the plasma, my question is can I get a scart to componant cable for my Sky to componant input on the receiver? That way I can then just run one componant cable from the componant out put on the receiver to the componant input on my plasma? So really I need to know can I get a scart to componant cable that will do what I want it to do please? If so does anyone know where I can get one from please? Any help would be appreciated as I need to get all this gear ordered soon.
My equipment is:
Hitachi 42PD5200 plasma
Planning on buying Yamaha Rx-V657 AV receiver and Yamaha DVDS557 DVD player, also a cheap VCR which will just be connected to the receiver with a cheap set of leads.
Hopefully, by having all of this equipment this will enable me to run all my cables into the Rx-V657 receiver and then just one componant cable to my plasma, not worried about a sound cable to the plasam as teh Yamaha will handle sound through the speakers rigged up to that?
Does all this sound feasable and what componant cables and scart to componant cable would you guys recommend???
Thanks for your help.
James
My equipment is:
James
