SCART to 15 Pin Cable?
Discussion in 'Cables & Switches' started by uksteve69, Jul 24, 2003.
  1. uksteve69
    uksteve69
    Jul 16, 2003
    70
    Telford
    First off, hello to all. I have just purchased a Sanyo Z1 projector and am after some info.
    I need a diagram of how to make up a SCART to 15 pin connector cable. The SCART is on my cable box and the 15 pin on my projector, the component connections on the Z1 will be used for the DVD player.
    There is also a 15 pin connector on the (Telewest) digital cable box, can I use that to connect to the 15 pin on the Z1 and would it be a simple cable box pin1 to Z1 pin1, cable pin 2 to Z1 pin2 etc?
    I have done a search but can't find the answers to these questions.
  2. uksteve69
    uksteve69
    Jul 16, 2003
    70
    Telford
    Found out the info in the LCD projector forum.
