scart sync problem
Discussion in 'Cables & Switches' started by charlie55, Nov 5, 2004.
  1. charlie55
    charlie55
    Jun 27, 2004
    1,293
    Falkirk
    +81
    i am in the process of making up a rgb scart to scart using ixos multi core cabling going between sky digibox and panasonic 42 viera plasma. my problem is that i don't know which pin to use in the scart for the sync signal.
    any help would be helpful as one of leading av shops in edinburgh as no idea after 5 weeks.
    charlie55
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,312
    Rainham Essex
    +2,425
    All the pins used in a scart plug are listed Here
    Mark.
  3. charlie55
    charlie55
    Jun 27, 2004
    1,293
    Falkirk
    +81
    i' sorry if i did'nt make it clear i have no real idea what i'm doing with the cable. just trying to get information so that a friend of mine can do the real work ie the soldering.
    i really need to know if pin 20 is the pin for the sync. signal as i have read on another site. also the pin numbers for the red green blue signals would be helpful
    sorry about mix up entirely my fault
  4. MarkE19
    MarkE19
    Aug 10, 2002
    17,312
    Rainham Essex
    +2,425
    Well from the link I provided you can get the following information as use for all the pins in a scart plug are listed.
    Red : pin15
    Green : pin 11
    Blue : pin 7
    pin 20 is not listed as a sync signal but as composite video. However this pin (or pin 19 depending on signal direction) is used as the RGB sync when useing an RGBS signal.
    Mark.
  5. charlie55
    charlie55
    Jun 27, 2004
    1,293
    Falkirk
    +81
    thank's for the info.but i tend to get a bit confused when the so called experts at a certain leading av dealers in edinburgh could'nt work out how to wire it up . i looked at the diagram on the site you recommended and it was as you say obvious how to go about it but after the crap i got from the dealers i just did'nt know what to do.
    anyway thanks i'll get on and get it made.
