Scart switcher with RGB...
C
chegz60
I want to connect Sky and PS2 thru same RGB scart on TV. Can anyone let me know where I can buy a Switch Unit for this purpose?
Cheerz:confused:
B Tech BT941 Quattro + (has a remote control too) from various places. Keene electronics has them at £79.99 at the moment. You may even find it a bit cheaper elsewhere.
I was under the impression that it's possible to daisy-chain RGB, in this case from the PS2, through Sky boxes to the TV?
Yes, this would be possible... as long as you aren't using the Digibox's 2nd SCART to connect to your video :p
Maybe the video is also capable of an RGB daisy chain.
Probably loads of interference and priority issues with
PS2 ---> Sky ---> Video ---> TV ;)
B-Tech B21, manual SCART switch, RGB & Widescreen switching compatible.
Argos do a similar one for £10
The remote Quattro at £80 is a bit of on overkill for your needs.
StormAudio ISR Fusion 20 AV Receiver - review coming soon #HomeCinema #Amplifier #VideoShort
Back
