Scart Switcher Problem
Discussion in 'Cables & Switches' started by Corvenstein, Nov 2, 2004.
  1. Corvenstein
    Corvenstein
    Nov 2, 2004
    228
    +75
    Hi, first post and a bit long winded for probably a simple question... but here I go.
    I have just purchased a Sony widescreen TV (KD-28DX51) and a Sony Home Cinema System (DAV-SR2) which is connected to the TV via the RGB scart socket. I have turned the speakers off on the TV and when I select the TV function on the DAV-SR2 it automatically switches to Freeview and the sound comes out its speakers.
    The problem is that I also have a PS2 that I wish to connect via the RGB socket so I purchased a scart switcher from Argos, made by Hitachi, but when I connect it all up I have good quality pictures from both the DVD and PS2 but no sound when the DAV-SR2 is switched to the TV function.
    I have had a look at the wiring on the scart switcher and only about 11 or so of the pins are connected, whilst on the scart lead for the TV all the pins are wired. The question is... is it due to scart switcher missing a vital wire or two which feeds the sound back from the TV to the DAV-SR2 and if so could anybody recommend a good quality scart switcher which supports this. I only need to be able to connect two RGB scart leads through it.
    Thanks in advance for you help.
    Richard
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,294
    +1,217
  3. Corvenstein
    Corvenstein
    Nov 2, 2004
    228
    +75
    Thanks for your reply, went into Dixons after work and managed to get the JVC one for £10.99. Worked a treat, thanks for your help. :thumbsup:
    Richard
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,294
    +1,217
    cracking arent they i use one for consoles....Cant have more than one input device on at once.
