Scart switch boxes (suitable for my set up?)
Discussion in 'Cables & Switches' started by Bob Beaney, Aug 20, 2004.
  1. Bob Beaney
    Bob Beaney
    Dec 31, 2003
    41
    11
    East Sussex
    Can anyone out there please advise me on whether this planned set up will be workable.
    panny PW6 + scart board + component board + Quintro 5 scart controller. Audio will be fed via Quintro stereo output to my pro logic processor the other side of the room.
    Although I know this will be fine for scart connected equipment like my sky box, what about the DVD player, which is to be connected to the component board and it's audio routed from DVD stereo outputs to Quintro stereo imputs, will the switch box still be able to output the audio to my processor when watching DVDs.
    I suspect and hope this is the case, but would appreciate confimation or not and any advice you might have.
  2. Bob Beaney
    Bob Beaney
    Dec 31, 2003
    41
    11
    East Sussex
    Seems I,m not going to get a reply to this posting. For what It's worth I will purchase the Quintro scart switcher (very usefull) and if I should find can't output DVD audio as wanted will buy from Keene Electronics a three way input selector BT31 (with one output) for 12.99 allowing me to use the scart switcher for routing sky box/VCR/and Xbox audio to my sound system while at the same time being able to bypass the Quintro when connecting the audio for the DVD player.The only other thing I will need is an additional pair of stereo interconect cables for linking the BT31 to the Quintros rear stereo outputs.
    One question? Is introducing this input selector likely to effect noticably the quality of the sound I finally get to listen to.
    Cheers.
  3. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    should work fine mate why not take DVD audio direct to processor.
  4. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    26,749
    The Borders
    +3,086
    Bob
    Doesn't the majority of your source kit offer 5:1 rather than just Stereo audio out.
    Best regards
    Joe
  5. Bob Beaney
    Bob Beaney
    Dec 31, 2003
    41
    11
    East Sussex
    Hi, :) Horney Dragon , Would do except Processor about 14ft away with only one set of stereo inputs and I don't want to keep pluging and unpluging my stereo output connections between the scart box and the DVD player which would also be difficult to get at.
    Thanks anyway for the sugestion.
  6. Bob Beaney
    Bob Beaney
    Dec 31, 2003
    41
    11
    East Sussex
    Hi Joe, Afraid not.Only DVD which is fed to my pro logic (only) suround system.
  7. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    26,749
    The Borders
    +3,086
    Hello Bob
    I'm sure your missing a trick with your X-Box - I don't believe its only go Stereo out!
    Best regards
    Joe
    PS B-Tech manufacturer the Quintro+. See http://www.b-tech-int.com/
  8. Bob Beaney
    Bob Beaney
    Dec 31, 2003
    41
    11
    East Sussex
    Hi Joe ,
    I'ld forgoten about the X box.Thats something Il'd need to look into.To be honest I never use it,belongs to my 12yr old son.Though come to think about it he can and often does connect it up to the surround .
    Thanks .
    PS thanks for correcting me on the Quintro manufacturer.
  9. helicon2
    helicon2
    Sep 5, 2003
    61
    +4
    Hi Bob,
    For your Xbox, you need one of the 'advanced scart leads' such as this one http://shop.game.net/ViewProduct.aspx?cat=10212&mid=305290. This has a digital optical out for connecting to you amp/receiver. Logitech also do one that has scart/s-video/composite with digital out.
    It's worth checking out cause on the right game (e.g. Halo), the stereo rear speakers are a treat!
  10. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    Unfortunatly with a Pro-logic only recevier with one set of inputs your choice is severely limited mate. a Quintro will work well, also have a search for the holden/holdan scart commander.
  11. Bob Beaney
    Bob Beaney
    Dec 31, 2003
    41
    11
    East Sussex
    That sounds good Ace2 but as mentioned in my postings on this thread I don't have 5-1 digitel suround,but pro logic (mono only for rear speakers) although I dare say I will have one day. At the present time I would find it hard to justify the extra cost to myself or the wife :nono: for that matter.
    Thanks anyway
  12. Bob Beaney
    Bob Beaney
    Dec 31, 2003
    41
    11
    East Sussex
    Thanks Horney Dragon,
    But have allready brought the Quintro.
  13. Bob Beaney
    Bob Beaney
    Dec 31, 2003
    41
    11
    East Sussex
    Hi all, :hiya:
    So far for my plasma set up I've managed to acquire (in addition to my long standing surround sound system) the following:
    1 pair of component cables (1Metre) Belden 7710A
    1 pair of hi-fi analogue cables (1 Metre) Canare LV61S
    1 scart controller (Quintro) BT945
    The Panasonic TH 42PWD6 to go with these would be good, but will have to wait due to the delay of about one month in receiving the money still to come through from the finalised sale of our flat which had been (due to unfavourable circumstances) up for sale for about 18 months.
    In case it might be of help to someone else with the connection of their system I will re -post the 1st posting of this thread (as shown above ) with the answer to the question I was asking. That's once of course I get my planned system up and running.
