SCART Switch Box Info Here....
Discussion in 'Cables & Switches' started by Kevo, Dec 18, 2003.
  1. Kevo
    Kevo
    Aug 23, 2001
    5,397
    Manchester
    +149
    Links to all your SCART switch box needs....
    All minimum 3 x SCART RGB compatible and from the cheapest places that I have come across.
    ---MANUAL---
    B-Tech BT21 Mk3
    http://www.beyondhifi.net/shopping/...p?ProductID=286
    'Argos jobby' which I think is a B-Tech B21 Mk3 clone
    Item code 534/2361
    http://www.argos.co.uk/webapp/wcs/s...0001&langId=-1&catalogId=1001&productId=60608
    B-Tech BT21-S
    http://www.beyondhifi.net/shopping/...p?ProductID=277
    ---AUTO---
    B-Tech BT945 Quinttro+
    http://www.beyondhifi.net/shopping/...p?ProductID=565
    Holdan HSR1000
    http://www.keene.co.uk/cgi-bin/bigcodesearch.pl?HSR1000
    Keene Scart Commander
    http://www.keene.co.uk/cgi-bin/bigcodesearch.pl?KSC
    Please feel free to add additions, corrections etc
    Moderator, might be a good idea to make this one a 'sticky'.
