Scart Splitter Without Captive Lead?
Discussion in 'Cables & Switches' started by Struan, Sep 4, 2004.
  1. Struan
    Struan
    Aug 24, 2002
    155
    Scotland
    Does anyone know where I can get a 3 way Scart splitter similar to the
    following item, but with a Scart IN socket rather than a captive Scart IN
    lead (preferably with a metal rather than plastic 'box')?
    CPC item (www.cpc.co.uk) - AV00934
  2. dakara
    dakara
  3. Swifttech
    Swifttech
  4. Struan
    Struan
    Aug 24, 2002
    155
    Scotland
    Thanks for the replies.
    I plan to use this item as follows:-
    To feed the output from a satellite receiver to 3 co-located VCRs (i.e. with standard length (1m?) Scart leads) - will I be able to do this using a passive splitter (similar to the CPC item), or is it necessary to use a distribution amp (similar to the Lektropaks item SCAMP2)?
    TIA.
