Scart Splitter or Switch Box
Discussion in 'Cables & Switches' started by LiquidTV, Oct 29, 2004.
  1. LiquidTV
    LiquidTV
    Sep 24, 2004
    169
    Cornwall
    Most of the cables that I ordered for the using the LCD have now arrived. However, I have found that my scart switch box is defective. It's cheap & nasty anyway. I am trying to find the best way to connect two TV's from one scart socket from the Sky digibox. I expect if I buy a scart splitter cable this will be at the expense of PQ?? If I go for a Scart switch box can anyone recommend a high quality one.
  2. father alice
    father alice
    Nov 30, 2003
    194
    +6
    got an amplified scart spitter box (1 input 2 outputs at the same time) from CPC for about £30 - includes a power supply. This results in lossless splitting of the rgb output from the sky box,with no need for selecting an output - does both at the same time, and works great.
  3. sapkan
    sapkan
    Jul 8, 2004
    496
    +4
    what is cpc?
  4. father alice
    father alice
    Nov 30, 2003
    194
    +6
  5. sapkan
    sapkan
    Jul 8, 2004
    496
    +4
