scart sockets
Discussion in 'General TV Discussions Forum' started by sparkymarky, Jan 6, 2003.
  1. sparkymarky
    sparkymarky
    Dec 12, 2002
    1,080
    48
    cornwall
    +32
    has anyone got a sony tv?
    mine has 2 scart sockets but only one is rgb compatible. i need to connect sky dig and dvd to rgb, so is a scart switchbox the only way or is there some option on the tv that shorts the scart sockets?
  2. Rolo Tomasi
    Rolo Tomasi
    Dec 13, 2002
    215
    +4
    You could try connecting the dvd player to the sky digibox with a scart lead so that both will use the same tv scart. This option will make recording from the digibox less convenient and there could be a slight reduction in dvd picture quality. Probably no worse than a switching box though!
    If you try this at least it will not cost you anything initially.
