SCART-SCART cable components...
Discussion in 'Cables & Switches' started by nealgs, Nov 20, 2003.
  1. nealgs
    nealgs
    Want to make up some short SCART->SCART cables to replace the ones I currently have which are to long really (1m) they only need to be 18"-24" long
    So, were can I get decent SCART sockets, and what cable would people recommend
    cheers and thanks
    Gary
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,299
    +1,215
    you can buy 0.5m scarts possibly even 0.3m scarts. CPC,RS etc sell the sockets/plugs and QED do some very nice cable.
  3. nealgs
    nealgs
    cheers HornyD :)
    can't find anything on QED site regarding just the cable. Only ready made stuff. Have you a link to the cable on you mention
    cheers
    Gary
  4. Brian110507
    Brian110507
    www.keene.co.uk do a good range of connectors and cables and supply them by mail order
  5. hornydragon
    hornydragon
    Dec 19, 2001
    28,299
    +1,215
    ERm its in the Veda catalogue IIRC you may need to go through a VEDA dealer to buy it as it is really for the CI market not the consumer market!
    PS hope your soldering is good I would never even attempt to solder a scart!
  6. Dominic
    Dominic
    Mar 2, 2001
    288
    Essex
    +6
    just an idea use your 1m scart assuming they are good quality and chop it in half, then apply a new scart end to each 0.5m cable and hey presto 2 cheap 0.5m scarts, with one original end and one new end
  7. nealgs
    nealgs
    Thanks for the hints/tips/links all.
    Dominic - good idea, but they are only cheapo Comet ones for £9 each so not much good, although there's nothing wrong with the picture produced from them.
    Keene have a Rear Entry/Flat cable ones which look pretty good, and suitable cable to. May go for them
    cheers
    Gary
  8. banners
    banners
    Jun 26, 2002
    439
    nottingham
    +16
    Gary, Good luck with this venture!! I have tried it before and the easiest way I found was to remove all the pins from the scart plug, solder and then re-insert them in their appropriate holes (oo-er!!). Patience is indeed a requirement ;)) Take your time and I'm sure you shall be rewarded with a great end product. With cheapo scarts available it may be worth your while a little practice.
    HTH
    Cheers Steve
  9. bobbypunk
    bobbypunk
    most companies will custom make you a lead as short as you want as long as you pay the normal rate for their listed options!
    I haven't checked individually but try dealers for
    QED, Ixos(?), and VDH
