Scart RGBS to 4 RCA pin out question
Discussion in 'Cables & Switches' started by jesone, Jul 8, 2004.
  1. jesone
    jesone
    Jun 18, 2004
    56
    +3
    Hi guys,
    I have a SCART to component 4 x RCA cable that I'm attempting to connect a Sky+ box (SCART) to an iScan HD (RCA) with but I can't get a picture. On looking at the SCART pinouts I see that the sync wire is connected to pin 20 (composite in), I was expecting this to be pin 19 which I thought was the composite out. Can anyone confirm whether this cable is correct?
  2. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    Sync is carried in the composite signal and AFAIK Scart cables are directional (i.e. either in or out, or they do have a switch on the connector). Thus you might have the wrong cable.
  3. acollins
    acollins
    Feb 21, 2002
    132
    16
    Portsmouth
    I am also wanting to know if i can connect sky+ to the 3 RCA sockets on the back of a plasma, the plasma is a 37pd5200 which has component and also a component which is also RGB. I have read somewhere that the RGB syncs on green. this means nothing to me!!
    What cable do i need?
    thanks
  4. Member 34135
    Member 34135
    It is not likely that you will be able set the Sky box output to sync on green, most consumer electronics requires the separate sync.
    The cable you need is the Profigold PGV7405/PGV7410 which is RGB+Sync Out.
    Andy.
  5. acollins
    acollins
    Feb 21, 2002
    132
    16
    Portsmouth
    Thanks for the reply, will this still work if there are only 3 inputs on screen? know where to plug sync in
  6. Member 34135
    Member 34135
    I'm afraid not, you'll need a sync input as well.
    Andy.
  7. noidea
    noidea
    Jun 8, 2004
    985
    46
    +123
    acollins, I think the AV2 socket on your plasma does have a seperate sync socket, which is where the composite cable would go if you were just using that - It is the socket that "completes the square" with the three sockets you are using for your RGB input.
    The cable mentioned above should work. QED also make a similar cable that also carries audio to the audio inputs on AV2 socket if you are using your screen for audio.
  8. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    'Component' (aka YUV) is not compatible to RGB, even though RGB is technically speaking also a component signal.
  9. noidea
    noidea
    Jun 8, 2004
    985
    46
    +123
    I think this particular phono socket on the hitachi can be set to accept either component or RGB.
  10. acollins
    acollins
    Feb 21, 2002
    132
    16
    Portsmouth
    Thanks for your replies, I havnt actually bought this screen yet but I am about to order, unfortunatly the only place i can get it from is currys and they do not have the the best setup to test connections on the screens.
    Regards.
