SCART (RGB) to HD15 pin (RGB)
Discussion in 'Cables & Switches' started by GMann, Jul 28, 2005.
  1. GMann
    GMann
    My DVD has a SCART RGB out put can I connect this to my LCD with an HD15 pin RGB input? if so where can I source a cable that will take me from SCART to HD15 pin
    GMan
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,330
    Rainham Essex
    +2,431
    Depends!
    You need to go into the setup menu of your LCD and see if the VGA input can be set to RGBcvS. If it can then you can get a scart to VGA cable from Keene.
    Mark.
  3. GMann
    GMann
    Thanks - would it be easier to go from SCART (RGB) to component video as my LCD has component inputs?
    Sorry I'm none technical!!!
  4. Gordon @ Convergent AV
    Jul 13, 2000
    14,201
    +3,036
    You'd need a rgb to component convertor to do that so it's likely to cost more. It may give you more scope for picture adjustment on your display though. The reason being that most RGB signal inputs on dsplays just give brightness and contrast controls whereas the component is likely to add colour, sharpness etc....
    Gordon
