SCart RGB to 4 x RCA Projector Cables...
Discussion in 'Projectors, Screens & Video Processors' started by Scart2RGB, Feb 4, 2001.
  1. Scart2RGB
    Scart2RGB
    I have been searching high and low for a high quality Scart to RGB (RCA type). Can't find one anywhere. Can anyone help please?
  2. Edgeyboy
    Edgeyboy
    Jul 31, 2000
    3,497
    Norfolk
    +168
    Lektropaks do one.
    I got one to go from an ondigital box to my VW10HT.
    Good quality lead too.
  3. pbess
    pbess
    Jul 14, 2000
    Newport
    Using this RGB cable does the 10HT work in 16:9 mode or does it default to 4:3? I've been told the Sony only works in 4:3 mode with a RGB connection becuase the projector beleives it's a computer input.
    What pins are used on the SCART connector?
  4. Paul D
    Paul D
    Dec 27, 2000
    2,781
    Manchester
    +550
    The Vw10HT uses the same Phono connections for the computer input, as it does for RGB+sync from your DVD/cable/satellite. So you just select "DTV GBR" instead of "Computer" from the input menu(allowing full resizing etc).<br />I'm using RGB from my DVD player at the moment and its a great improvement over Svideo, this may have been because i have to use a very long(30ft+) lead.
  5. simoncope
    simoncope
    I presume this just works for interlaced RGB from sat boxes and the like (ie only at a H freq of 16.5 kHZ). One of the main changes Sony are making for the upcoming VW11 (allegedly) is that it will allow proper handling of 16:9 RGBHV signals (they currently display as a 4:3 image in the middle of the screen as you say)
