SCART RGB + Sync
Discussion in 'Cables & Switches' started by ianh64, Oct 1, 2004.
  1. ianh64
    ianh64
    Aug 7, 2004
    2,233
    SW London/Surrey borders
    +63
    Just want to confirm where the synch is on a SCART output. Searching the forum, it appears to be RGB + synch on composite - ie 4 cables required.
    Is this correct or is it implementation dependant? I Have a Pace Twin Freeview recorder outputting on scart. My TV will take RGB over the 3 RCA component input and I am investigating using my component (YUV) switcher for switching RGB too. The manufacturers imply that the sucess of this is dependant on synch being on green or on composite - they have not yet said which - I suspect it will only work with synch on green - 3 cables.
    Is it possible to convert between synch on green or on composite?
    Ian
  2. pjclark1
    pjclark1
    Jul 19, 2004
    4,463
    Thailand
    +271
    USA have sync on green (3 wires)
    UK have sync on composite (4 wires)
