scart rgb or s-vhs setting
Discussion in 'Blu-ray & DVD Players & Recorders' started by laurence harvey, Dec 30, 2000.
  1. laurence harvey
    laurence harvey
    lo all.. AGAIN.. blush blush, told u all im new to this, but I appreciate the collectives superior knowledge...[too much creeping ?].
    right, should I use the setting on tosh 200e dvd set at rgb scart or s-vhs as the panasonic 32 dk1 will take both settings...
    should i use a certain av channel as well ..thanks all
  2. ReTrO
    ReTrO
    Jul 12, 2000
    3,506
    2
    71
    High Wycombe, Bucks, UK
    +59
    Ues the RGB option. There is a perceiveable difference in the picture quality between RGB and S-video, well I can tell anyway. Even if it is on an £8.5k PDP and Arcam DVD... (PS not mine, at work).
    For the AV 'channel' option, these refer to the SCART and front panel inputs, so you will need to use these. It should auto switch anyway, my 25" panny does, and use AV1 since this is the RGB input.
    Hope this helps!
    Rick
    'I am just a figment of your imagination.'
    MiB 1997
    Work Site: The Sound Gallery
    Home Site: WD A.V.
  3. bradavon
    bradavon
    Use RGB through Scart. Loads better picture quality than S-Video.
  4. laurence harvey
    laurence harvey
    thank both 4 taking the time to reply to such a simple question, i will learn ...i promise !!! [​IMG]
