Scart problems
Discussion in 'Satellite TV, Sky TV & FreeSat' started by simonv74, Oct 5, 2003.
  1. simonv74
    simonv74
    Please can someone help!
    Please can someone help me? Got a new digi box connected to my TV using Scart, and also DVD player using Scart too. Scart lead connected into the second port works fine (for both digi box and DVD), but when either are connected to the first one then the screen just flickers (it is connected to the TV ok).
    Second scart port says audio/video yet first one is not labelled.
    Second port accepts RGB and PAL signal, yet first one is black screen with PAL yet flickering with RGB.
    Tried all combinations and still doesn't work.
    Any ideas, I reckon it's just knackered, but am I missing something obvious?
    Anyone got a Toshiba 2112db (or similar) manual knocking around!?
    Got me stumped!
  2. John_sg0107
    John_sg0107
    Aug 13, 2003
    33
    Newcastle
    I have also had a similar experience with my Toshiba Tv and an S-Video cable. I didn't realise that you can change the different scarts via the on screen menu. It maybe something simple like that ?.
