(SCART PROBLEM) Sanyo CE28WN4-B
Discussion in 'General TV Discussions Forum' started by Moncs, Jan 15, 2002.
  1. Moncs
    Moncs
    Jan 14, 2002
    467
    Edinburgh, Scotland
    I'am having a problem with my new Sanyo widescreen TV, sadly Im not to clued up on TV's etc so I would be greateful for some help.
    I have a Sanyo CE28WN4-B widescreen TV which has 2 SCART
    sockets.
    Whenever I plug anything (SKY, PS2 etc) into AV1 (RGB) then I get perfect picture apart from being quite dull and I cannot change the colour/contrast etc.
    When I plug anything into AV2 (S-Video) the picture is not as good but the colour is a lot better and I can change it if required.
    Do you know if this is a problem with the TV or if there is a cable I
    could buy so I can have a perfect picture with good colour??
  2. Doubledoom
    Doubledoom
    This is totally normal and nothing is wrong.
    RGB shows the picture as it should be seen. However, some people prefer higher contrast and colours.
    You need to make your choice.
