Hello all, Yesterday I bought a Pioneer DVD 464. Beautiful machine. In the shop they made it region-free. When I came home I connected it tom my Tv, an LG which I bought just three years ago, and I have a beautiful razorsharp image using RGB Scart with Region 2. Now I decided to put a region 1 disc in it, and it played well, however I noticed that the picture would sometimes be very dark and suddenly went bright again, kinda like a macrovision protection. I even tried the mod.pal option on the player, but no effect. When I change the RGB option to Video in the menu of the player, this effect no longer happens. Funny thing is I connected everything to an even older tv to see if it was perhaps my scart cable and there it worked perfectly, even on region 1 with rgb enabled. Now I'm going nuts Could this be a scart cable quality thing, or do I need a brandnew tv ? Any help would be greatly appreciated
Hi, I had something very similar on my Pioneer 757. I believe it is a macrovision / RGB problem and the only way around it is get the macrovision disabled on your player or buy a new TV!!!!!!!!!!! Russ
Hi Russ, Thanks for giving me some info. I suspected it was a macrovision problem. Do you know a way to disable macrovision on my player?
I'm afraid the only way you're going to stop this happening is to use the s video output. Pioneers have a tendency to do this to some TV's - panasonic in particular - and some Sony's... Nothing will stop it on R1 DVD's other than switching from RGB...sorry.
JUST got a pioneer dcs 515 player,with multiregion from a store. I have exactly the same problem...region 2 is perfect, region 1 is weirdddd....watchable...but its annoying to have hissing sound/poorer quality picture than region 2,with pixellations/glimmering-vibrating corners of the picture.... Obviously,i am going about finding what my problem is....Nobody knows yet. My tv is only 3 weeks old,and only out about a year.Mitsubishi.. ntsc/pal playback...also,as advertised. So shouldn't ntsc discs play???perfectly?.The tv somehow of dvd player...won't join in tandem,to create a powerful force!....like region 2. I don't know..about this macrovision thing....what is it?. I will prob send the dvd player back to richer sounds.
