Scart problem on Panasonic
Discussion in 'Cables & Switches' started by Fourway, Aug 5, 2006.
  1. Fourway
    Fourway
    Feb 2, 2006
    20
    3
    I have a Panasonic TX28 100hz TV and If I connect my DVD player to AV2 the picture quality is a lot poorer than if It goes though AV1. When on AV2 it s like a criss cross pattern is in the background, enough to be noticed but not totally ruin the picture. I've tried every permutation of the settings but nothing seems to work. Is there something different about AV2, is it only meant for particular items. I had this effect on my last Panasonic as well , with other dvd players so I assume the issue is AV2.
  2. koe717
    koe717
    Sounds like you have set it to s video.
    When you are on av2 press the green button on your tv remote until you get a good picture.
    If it shows av2s it is set to s video. press the green fastext button twice to get off the s video connection.:thumbsup:
    Hope this helps.....
    koe
  3. Fourway
    Fourway
    Feb 2, 2006
    20
    3
    I can't believe it. I've tried everything and that sorted it. TBH I always thought that was a 5 not an S but there you go. Thanks for your help!
  4. Jaap
    Jaap
    Thanks! Worked for me too.
