Scart problem. I need 2 outputs
Discussion in 'Cables & Switches' started by blue_tarragon, Feb 1, 2005.
  1. blue_tarragon
    blue_tarragon
    I have lots of equipment all connected together via RGB scart leads and a scart switch box (Quattro+) - DVD, Xbox, PS2, Sky+ etc.
    All is perfect and it is connected up to my plasma.
    I am now going to add a projector to my setup but my scart box only has one output (going to the plasma).
    What is the best solution?
    I want to run an RGB scart to the projector, but there is no room for it. I assume I need to run the cable which is going to the plasma at the moment into another device which then splits it to the plasma and the projector?
    But all the two way switch boxes I seem to find have 2 inputs and one output.
    Any help would be much appreciated.
    Many thanks.
