Scart problem 2 cables or 1
Discussion in 'Cables & Switches' started by flipfella, May 14, 2005.
  1. flipfella
    flipfella
    Dec 31, 2003
    155
    28
    Thirsk
    +33
    I need a scart for my upcoming projector. to connect my tivo etc...
    It needs about 7.5m, so do I get a 10m scart or a 5m and a 3m with a joiner.
    So is it better to have a single longer run (10m) or a shorter one with a scart joiner (8m)
    fliP.
  2. andylorenz
    andylorenz
    Mar 12, 2005
    98
    +10
    you are always going to be better with a single cable, any joins you make just add the potential for signal loss. Plus the price for 10m of half decent cabling is probably cheaper than 2 cables of smaller length.
    when you say scart connection, do you mean composite, RGB or component, and what are you doing about sound?
    I don't know what a tivo outputs but be careful you check, as I have been caught out myself by connecting to my projector only to find my RGB signal also needs sync which isn't supported by the cable I got.
  3. flipfella
    flipfella
    Dec 31, 2003
    155
    28
    Thirsk
    +33
    thanks for your input
    the cable is for RGB, so I was going to use a 21 pin wired cable. I'm also running s-video and component to the projector, (going to run a digital cable at a later date when I have a digital output)
    I think your right though, a 10m cable will work out better, I don't go joining any other cables in my system, so I won't bother with this one.
    fliP.
