Scart pins and remote problem?
Discussion in 'Cables & Switches' started by caleb2002, Jun 20, 2004.
  1. caleb2002
    caleb2002
    I have been having an IR interference with myt Tivo and Toshiba Tv.
    Since I added the Tivo sometimes the TV remote doesnt work for about 1 minute and I cant change anything, also at the same time the Tivo remote wont work for the TV volume as well.
    When testing I found that when the TV remote didnt work neither did the front panel buttons on the TV itself, so I was thinking it may be a scart issue and lo and behold when I unplugged the tivo scart from the tv the remote burst back into life.
    Bearing this in mind, is their a pin on the scart that can be disconnected that might fix this?
    Thanks for any replies
