scart over cat5, can i do it?
Discussion in 'Cables & Switches' started by lee2lee, Nov 28, 2010.
  1. lee2lee
    lee2lee
    Nov 22, 2010
    4
    Can i run a cat5 and put scart connectors on the end?
    i have a tv in my bedroom and i want to run a scart to it for sky, i have ran a cable from the RF output but dont like the picture quality.
    does the sky box use all the pins on a scart cable?
  2. amgard
    amgard
    Oct 12, 2005
    460
    near Oxford
    +88
    you need to use something like this:
    madnat baluns
  3. lee2lee
    lee2lee
    Nov 22, 2010
    4
    so how do they work then ?
    thanks for the reply.
  4. amgard
    amgard
    Oct 12, 2005
    460
    near Oxford
    +88
    the SCART transmitter plugs into the Sky box, the SCART receiver into the TV in your bedroom, and you run CAT5 between the two.
  5. lee2lee
    lee2lee
    Nov 22, 2010
    4
    how does the technical part of it work ?
    why cant i just solder onto the scart pins ?
  6. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    28,746
    The Borders
    +3,517
    The unbalanced signal the Source is outputting via SCART is not designed to run over long cable lengths – the extender Transmitter takes unbalanced in and outputs a balanced signal that will run over the twisted pair for the Receiver to convert back to unbalanced.
    Balun - Wikipedia, the free encyclopedia
    You can try a straight run over CAT5 but don't be surprised if you get a poor image or no image.
    Make sure the extender you plan to use A. caters for RGB video and B. caters for audio or run audio over its own extender/receiver + CAT5 cable.
    Joe
