Scart or Component
Discussion in 'Blu-ray & DVD Players & Recorders' started by GeordieKeith, Jan 6, 2003.
  1. GeordieKeith
    GeordieKeith
    I am not sure but I am sure the DAVS offers both a RGB(Scart) and component output. Which one will give me the best picture quality please.
    Also has anyone used Cambridge Audio 2M Premuium scart cables (from Richersounds I think) and are they any good.
    Thanks.
  2. Jasonjo
    Jasonjo
    Dec 3, 2001
    2,677
    UK
    +115
    In theory component is better, but RGB scart is quite close behind unless you are using a high quality display. I would guess there is very little in it on the DAVS...
    I would think a good quality scart would be the one to go with, I would suggest one for £30-50 if you have a decent TV - check out ones from Ixos, Supra or QED.
    JJ
  3. GeordieKeith
    GeordieKeith
    Its a KV32FX66 television. Can you recommend anywhere online to get these from
    Thanks.
  4. Dutch
    Dutch
    Dec 5, 2002
    2,601
    2
    5
    North Yorkshire
    +284
    Hi Keith,
    I don't think the Sony DAV-S series have Scart outputs, so component will be your best bet. But as you've got that Sony TV, you will need an s-video to Scart lead. Any of those makes Jason mentioned are fine.
    Steve
  5. Jasonjo
    Jasonjo
    Dec 3, 2001
    2,677
    UK
    +115
  6. GeordieKeith
    GeordieKeith
    Last one, I promise! Does the SVHS output on the DAVS system support RGB? If so I am looking for a RGB Wired SVHS -> Scart Lead.
    Sorry for the questions, to cut a long story short I have bough the DVD and TV but they are still in the box and will be until I move. Nightmare!!
    Thanks for the replies.
  7. Dutch
    Dutch
    Dec 5, 2002
    2,601
    2
    5
    North Yorkshire
    +284
    Hi Keith,
    You won't get RGB from an s-video output, only s-video (!) I'm afraid. You can only get RGB from a suitable DVD Scart. Now if you can swap your TV for one of the component-equipped Toshibas...:p
    Steve
