Scart MAD
Discussion in 'TVs' started by jenic, Jan 3, 2005.
  1. jenic
    jenic
    Dec 10, 2004
    2,871
    83
    +179
    Why do companys make everything audio/visual require scart connection? And then they only give us 3 sockets (if u r lucky) on the tele. It is driving me crazy. I have 2 scarts on my tv which are required to connect my DVD, Freeview, Xbox and PS2, my video has 1 scart that i use for my xbox and i connect my video via rf. This can't go on, when i get my DVD reccorder it will be another scart!
    Tvs should have at least 4 scarts, i am sure a tv with 4 or more would be very popular. I know you can get fancy switches and stuff but really they are no match to a true scart with its own av channel.
    :thumbsdow
    Something needs to be done
  2. TV Headache
    TV Headache
    Mar 3, 2004
    242
    16
    I think Sony's KV-36HQ100 has 4 scart inputs.
    Will you still need to keep your DVD player connected when you get your DVD recorder?
  3. mansell
    mansell
    Feb 11, 2002
    754
    28
    Bristol
    +39
    My Sony has four
    but only two are RGB and I have three devices which will accept RGB ,DVD player , sky+ and xbox .
    however the xbox is connected to the pass through socket on the back of my sky+ as it does pass through RGB.
    I therefore have one unsed socket, the other non rgb is connect to my amp (composite into scart) so I can view my system settings on the TV
  4. jenic
    jenic
    Dec 10, 2004
    2,871
    83
    +179
    My dvd plaer is also a home cinema, so i will always need it!
  5. Tight Git
    Tight Git
    Mar 3, 2004
    6,332
    +597
    Because, although not technically ideal, Scarts are reasonably foolproof in the hands of the general public due to their auto-switching facility.
    Remember most people have trouble just setting their VCR timer!
    I agree there should be more on a tv, but it's economics as usual.
