Scart leads
Discussion in 'General TV Discussions Forum' started by DavidT, Jan 14, 2002.
  1. DavidT
    DavidT
    Oct 30, 2001
    2,490
    +257
    Just bought a couple of scart leads from my local hi-fi shop. I asked for fully wired and was sold 2 leads that look like black ribbon cable with gold scarts at both ends. I don't know who the manufacturer is.
    Do these sound ok? They are 75cm long and I paid £7 each.
  2. Kevo
    Kevo
    Aug 23, 2001
    5,448
    Manchester
    +166
    Yes, they're fully configured, I used to have one of these, but I prefer the normal type. The ribbon cable type aren't very good for connecting devices which are side by side, they're not as 'flexible'.
    I think they are designed for devices which are stacked in a rack system.
    It depends on how your system is set up.
  3. Doubledoom
    Doubledoom
    £7 ribbon leads are unlikely to be well shielded so although these are gold pinned, the more important shielding is unlikely to be there.
