Scart leads
Discussion in 'Cables & Switches' started by Garrymol, Aug 7, 2005.
  1. Garrymol
    Garrymol
    Feb 3, 2005
    43
    Wirral
    Hi again Peeps,
    Just a quickie will good quallity scart leads make difference in PQ
    And if so any reccomendations, Thanks.
    Garry
  2. GalacticaActual
    GalacticaActual
    Jun 1, 2004
    5,864
    Galactica C.I.C.
    +279
  3. lynx
    lynx
    Jan 20, 2002
    4,651
    It always rains.
    +302
    Moving to cables forum.
  4. bluefoxtim
    bluefoxtim
    Jul 28, 2005
    43
    +3
    silver plated scarts and gold plated scarts have a HUGE HUGE HUGE difference!
  5. Member 34135
    Member 34135
    The plating actually makes very little difference, what does make the difference is the quality of cable, 75 ohm coax conductors for the video and individually shielded. The higher quality cables tend to have gold plated contacts but this is not always a sign of a good cable.
    The silver coloured contact leads are nickel plated not silver, you can get silver plated copper cable, eg the Ixos XHT801-150 but these have gold plated contacts.
    Andy.
