Scart leads and HDMI connections
sherbert79
I was wondering if there is any way you can connect an NTL box using a HDMI instead of a scart? Also does the picture on an LCD vary depending on the quality of your scart?? :thumbsup:
neilmcl
Ah the million dollar question again. For a start I'm pretty sure NTL boxes don't have a digital connection so no you can't use HDMI. As far as scarts are concerned some people will tell you that they can't see any difference between a cheaper £5 scart and a £50+ one. Personally I don't think you need to spend silly money but I changed my standard Sky supplied scart with a £30 Supra FS and I can definitely see and hear a difference in quality.
