scart lead
Discussion in 'Cables & Switches' started by mw3cdj, Dec 21, 2003.
  1. mw3cdj
    mw3cdj
    Nov 12, 2002
    399
    West Wales
    Hi all,
    At the moment i am feeding a RGB signal from a sky+ box into a JS TECHNOLOGY RGB to YUV converter via a IXOS scart lead. Would it be of ant benefit to upgrade the scart to something of a higher quality. If so any suggestions??
    Daran
  2. bobbypunk
    bobbypunk
    depends on your budget and which Ixos you currently have
    There is a XHT801 (£70) which is fairly good or if you have a little higher budget VanDenHul's THESCART is amazing @ (£85)
