Scart lead which blocks copy protection for DVD70R
Discussion in 'Blu-ray & DVD Players & Recorders' started by greg_1979, Jan 24, 2005.
  1. greg_1979
    greg_1979
    Hi all, bit of advice required if you'd be so bold...
    I have a Philips DVDR70 (DVD recorder) and a Toshiba SD???E (player, can't remember digits) and I want to get hold of one of those special scart leads that blocks the copy protection signal?
    Can someone point me in the right direction for one of these and also confirm that it will definitely work with this set up? Maybe someone who has specifially tested one of these leads on a DVDR70 could let me know for sure? At the moment, I press play on the player and record on the recorder and the recorder displays the message on the LED screen saying "Copy Protected".
    Hope someone can help me!!
    G
  2. ColonelK
    ColonelK
    Jan 7, 2005
    85
    Coventry
    I don't think people are allowed to share info on Copyright circumvention.
    Google is your friend...
  3. ivanwilson
    ivanwilson
    Oct 31, 2003
    111
    Belfast
    I think such leads only remove Macrovision (flashing screen) protection. I think that DVD's also have another means of protection (CPRM?) which means that in theory you cannot copy using this method; and your recorder will not allow you to go into record mode.
  4. greg_1979
    greg_1979
    Okey dokey. Does anyone know if these scart leads only removes the Macrovision protection or are there any that can remove this other form of protection mentioned in the thread above?
    If not, are there any other methods of "tricking" the recorder into ignoring the copy protection signal from the original DVD? Or a code?
    Any help is greatly appreciated.
  5. ibrox50
    ibrox50
    Nov 12, 2004
    91
    11
    glasgow
    try www.sonel.com they will sell you a scart for about £25 handy for making backups
  6. greg_1979
    greg_1979
    Cool. Thanks for the link. However, do you know if this only removes Macrovision or does this allow me to make back-up's onto my Philips DVD Recorder of pretty much any DVD (which is what I'm after)?
  7. Dickdastardly
    Dickdastardly
    Try http://www.ktvision.com/ . Some info there, and a contact E mail for specific advice ( apparently anyway, so I've heard - not that I would be involved with stuff like that :nono: )
