Scart Lead Though Wall Plate
Discussion in 'Cables & Switches' started by dann, Feb 28, 2005.
  1. dann
    dann
    Aug 25, 2003
    134
    Hi, I need some help on the following:
    I am about to chase a wall out to bury cables to connect sky+ (via Scart), Xbox (scart) & a DVD (via Component) to a Viera.
    I have decided to pass the cables though a wall plate instead of using wall plate sockets (from advice in this forum).
    My question is, Can anyone recommend a half decent Scart Lead that will allow me to remove the casing on one end of the plug, This would be allow me to create the smallest hole possible in a blanking plate, Then use a gommit to cover the rest of the hole.
    Can you also recommend a 'Xbox to Scart lead' the same as above.
    These cables need to be about 3 Metres Long,
    Although this has been asked 1000 times, I will stick it on the end of the thread anyway, Can you recommend a Good Component cable.
    Finally, I am not worried about Future Proofing as will be moving within 5 years, & will not be replacing any thing in that time.
    Thanks for your time.
    Dan
