SCART input for Sony PFM42B1E
Discussion in 'Plasma TVs' started by adhawkins, Jan 2, 2005.
  1. adhawkins
    adhawkins
    Jan 2, 2005
    43
    11
    Swindon, UK
    +4
    Hi all,
    I'm about to get a Sony PFM42B1E plasma. My current kit is a Sky+ box, feeding via RGB SCART into a Pioneer 420 Hard Disk / DVD recorder. The RGB SCART output of the Pioneer then goes into an RGB SCART on my Sony CRT TV.
    What is the best way of connecting this up to the Plasma? As I understand it, the Plasma has VGA, Composite and S-Video inputs (but no SCARTS).
    The Pioneer has an SVideo output. However, to get best quality, do I need something to convert from the RGB SCART output of the Pioneer to a VGA connector into the Plasma?
    Any advice would be appreciated.
    Andy
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    a JS tech RGB>VGA coverter may be the solution you need check out the site for more
  3. adhawkins
    adhawkins
    Jan 2, 2005
    43
    11
    Swindon, UK
    +4
    Yeah, spotted them. The price tag of about 150 quid is a little scary though...
    Where's the best place to get them from? Would I see a noticeable difference between that and SVideo?
    Andy
  4. tamthetim
    tamthetim
    Nov 7, 2004
    478
    Perth
    +6
  5. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    iscan HD is another option @ £900
  6. adhawkins
    adhawkins
    Jan 2, 2005
    43
    11
    Swindon, UK
    +4
    Didn't you say that a couple of posts ago? :)
    Andy
  7. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    yeah sorry had a history issue now edited but if the JS box works tis the best way to add an RGB scart to the screen note it is RGB only and can be used with a scart switcher to add mulitple inputs...and why the SONY anyway?
  8. adhawkins
    adhawkins
    Jan 2, 2005
    43
    11
    Swindon, UK
    +4
    My mate is moving to a smaller place, so wants to get a smaller screen. I'm getting his Sony in return for buying him another telly (about a grand or so).
    Sounded like a good deal to me...
    Andy
  9. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    not bad mate bet you he will miss it tho.......32" Hiachi are just over £1k
  10. adhawkins
    adhawkins
    Jan 2, 2005
    43
    11
    Swindon, UK
    +4
    I'm sure he will miss it! Not sure which one it is he's getting, we ordered it a couple of days ago.
    Andy
