SCART female to four BNCs... where?
Discussion in 'Cables & Switches' started by Easy2BCheesy, Jan 11, 2004.
  1. Easy2BCheesy
    Easy2BCheesy
    May 8, 2003
    343
    16
    Hi there -
    As per the title really. I'm looking for a female SCART plug to four RCA/BNC cable.
    This is so I can connect the likes of my PS2, Xbox, Sky, DVD player into my RGB capture card.
    I've found male SCART plugs to BNC, but not female. I really need the female for the flexibility of being able to put my games consoles into the capture card.
    Any one know where to get such a lead?
  2. Brian110507
    Brian110507
    have you considered just using a scart coupler, - plugs into a male and turns it into a female, !!!
    as a 'for instance' go to www.keene.co.uk browse to the 'products' page and search for product code KA146
  3. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
  4. Easy2BCheesy
    Easy2BCheesy
    May 8, 2003
    343
    16
    Cheers for that - £36 for the lead and adaptor from Keene, which isn't *that* bad.
