SCART Component to VGA???
Discussion in 'Plasma TVs' started by chez, Nov 25, 2003.
  1. chez
    chez
    Feb 25, 2003
    1,549
    41
    Dallas, TX
    +19
    I've got a meridian 596 DVD player with the SCART output and am considering getting a Panasonic TH42PW6B.
    According to Meridian, the SCART socket can output Composite, S-Video, RGB, YPrPb (non-standard), Blank (for 2nd zone) and EUROSCART.
    If it can output YPrPb (albeit non-standard), could I get a lead made to connect from the SCART out of my DVD player to the VGA in on the Panny??
    Thanks in advance
    Chez
  2. Bob Todd
    Bob Todd
    Aug 20, 2000
    3,080
    UK
    +373
    try keene.co.uk
    expect to pay between 30-40
  3. chez
    chez
    Feb 25, 2003
    1,549
    41
    Dallas, TX
    +19
    will they make a lead up for me?
    Surely if I buy an off-the shelf lead, it will not work due the component being non-standard??
    Does non-standard mean that the pin configuration may not be standard??? I'm a bit confused!!
  4. Bob Todd
    Bob Todd
    Aug 20, 2000
    3,080
    UK
    +373
    email keane directly make sure you provide them with all the details and they will do the job, because thats what they are good at, but expect to pay a fair bit more then normal.
    The dont use the best shielding etc on their custom leads but they certainly are better then budget ones, and u can get it maid to the exact length u require.
  5. MAW
    MAW
    Jan 24, 2002
    14,082
    Nr Dorking
    +412
    You're better off with lektropacks for that, or if all else fails I'll make you one, I have a 3m one in my hand about to be installed this AM.
