Scart cables and adapters: RGB as standard?
Discussion in 'Cables & Switches' started by SyG, Apr 24, 2005.
  1. SyG
    SyG
    Apr 24, 2005
    138
    Simple question – do all 21 pin scart connectors transmit RGB, or do they have to be ‘special’ RGB scart pieces of equipment?
    Answers apprciated! :smashin:
  2. vizslaraner
    vizslaraner
    Dec 13, 2003
    424
    Hereford
    A fully wired SCART will cover everything (composite, s-video and RGB) and is non-directional. There is a view, however, that unused cores may aid interference/signal degradation hence the introduction of RGB only SCARTS which, if I remember correctly, are directional.
    Personally, I've never had any problem with fully wired and prefer the flat variety for ease of connection.
  3. SyG
    SyG
    Apr 24, 2005
    138
    OK, thanks!
  4. thedude
    thedude
    Oct 18, 2004
    8,652
    Swindon
    +1,616
    we sell some at comet that have 21 pins but dont send RGB be warned
  5. SyG
    SyG
    Apr 24, 2005
    138
    Ooh, hang on - does this apply to switcboxes also?
  6. vizslaraner
    vizslaraner
    Dec 13, 2003
    424
    Hereford
    Unfortunately yes, though the product description should tell you what type of signals/functions the product supports.
    For example, this device only supports stereo audio and composite video, whereas this device supports S-Video on all inputs and RGB on four.
  7. SyG
    SyG
    Apr 24, 2005
    138
    Hmm... this makes things a bit more difficult, but I'm in the know now.
    OK, thanks!
  8. vizslaraner
    vizslaraner
    Dec 13, 2003
    424
    Hereford
    Is there something specific you're after?
  9. SyG
    SyG
    Apr 24, 2005
    138
    Well, I'm sorting my newly decorated bedroom out (moved a few months ago and have been sleeping in a wallpaperless, carpetless hole until now). The electrics are all coming out and I'm getting a 21" TV with two scarts and a composite input.
    Only one of the scarts is RGB, and I want an audio output anyway. The composite is input only, so I plan to use the non RGB scart as audio out and want to get for games consoles and a DVD player into this one scart socket. After all of the info I've gathered, I'll probably go for this. I'd love to get a Quintro, but money- y'know? The DVD player will probably have to go into the composite. :rolleyes:
    If I could split the second scart so that I could input a signal and output audio simultaneously, that'd be great for the non-RGB consoles, so the DVD could go in the scart multi-box, but I don't know if that's possible.
  10. vizslaraner
    vizslaraner
    Dec 13, 2003
    424
    Hereford
    I bought a 3 in 1 manually switchable RGB SCART block from Game (£9.99) for my son (he's got a Freeview Box and a PS2). The one you're looking at appears to be a 4 in 1 manual RGB SCART switch block.
    Plug your DVD player and games console/s into the inputs of the SCART block (obviously these leads need to be RGB compatible; i.e. your best bet would be fully wired) and then the flying lead of the switch block into the RGB SCART of the TV. Switch inputs to the TV on the block.
  11. SyG
    SyG
    Apr 24, 2005
    138
    Ya, but I have 4 consoles and a DVD player - totalling to 5 inputs. That's where the problems start!
  12. vizslaraner
    vizslaraner
    Dec 13, 2003
    424
    Hereford
    It may be a bit ungainly, but you could always daisy chain two switch blocks.
  13. SyG
    SyG
    Apr 24, 2005
    138
    Well, I've thought about this, but I'm worried about signal loss. :(
  14. vizslaraner
    vizslaraner
    Dec 13, 2003
    424
    Hereford
    Don't be.
  15. SyG
    SyG
    Apr 24, 2005
    138
    How come? Surely it'll get pretty ugly once a signal has been through TWO switch boxes?
    I did ask about this here, but I got no reply. :(
  16. vizslaraner
    vizslaraner
    Dec 13, 2003
    424
    Hereford
    They're just passive switch boxes, no different to daisy chaining SCART leads to make one long one.
  17. SyG
    SyG
    Apr 24, 2005
    138
    I would've thought that daisy-chaining scarts would give signal degredation too.
    Well, if you're sure, I'll just get another decent scart box and wire 'em all up. Now my only problem is getting it all to look tidy...:rolleyes:
