SCART Cable - is it Composite or RGB?
Discussion in 'Cables & Switches' started by NNOMANN, Dec 7, 2004.
  1. NNOMANN
    NNOMANN
    Nov 2, 2004
    20
    Hi there.
    Is there any way of telling whether a SCART cable is RGB? I've been digging around in the loft and have found a couple of cables whose origin I am unsure of!
    Cheers,
    NOMAN
  2. Ian J
    Ian J
    Aug 6, 2001
    25,528
    +4,906
    If a scart cable is fully wired it can handle RGB as well as composite.
    Cables known as "RGB Scart" will not be fully wired as they won't handle any audio for starters.
  3. NNOMANN
    NNOMANN
    Nov 2, 2004
    20
    Cheers for that Ian.
    How can I tell if the cable is fully wired or not?
    NOMAN
  4. Bubbauk
    Bubbauk
    Sep 27, 2004
    178
    Belfast
    +4
    If you look at the scart connection and it has all the pins it is generaly fully wired but just to make sure if you dont mind opening each end of the connection and making sure then you can tell if its fully wired.
