Scart Cable for PS2
Discussion in 'Playstation Forums' started by Rookies, Feb 22, 2003.
  1. Rookies
    Rookies
    Jan 4, 2003
    4,929
    103
    +349
    Have anyone found any good scart cables for PS2 that can carry RGB or S-Video to scart
  2. Kazuya Mishima
    Kazuya Mishima
    Dec 11, 2002
    1,416
    North East Scotland
    +65
    Try the "Blaze" RGB Scart for PS2, you can buy it in Virgin Megastores.
    It also has separate stereo outputs if you require.
  3. Garbo
    Garbo
    [​IMG] Thats the one I've got, it allows you to switch between RGB for game and composite for DVD's so you don't get the 'green screen' recommended.
  4. MattDX
    MattDX
    Get a DVD multi region disc (or action replay) for the PS2 and you can watch DVDs in RGB without the green screen!
