SCART cable - 10m - THIN! Possible?
Discussion in 'Cables & Switches' started by kissakiwi, Mar 20, 2005.
  1. kissakiwi
    kissakiwi
    Mar 20, 2005
    4
    I have a Projector mounted on ceiling which has an RGB SCART IN connection amongst others. Right now I am using S-Video.
    I would like to use RBG SCART as then I can run PS2, NTL, etc as well as DVD to PJ. I need to run approx 10m of cable for the SCART connection. The problem I have is that normal round (21 core) or Flat SCART cable will be too think to run thru the conduit I installed a long time ago.
    Does anyone know where I can purchase some sort of 'thin cable' which would do the trick?
    I'm in UK BTW.
    KK
  2. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    24,276
    The Borders
    +2,573
    Kissakiwi
    What diameter of cable can you accommodate - and can you assemble one of the SCART hoods on site?
    Joe
