Scart auto switching
Discussion in 'Cables & Switches' started by garymeg, Dec 13, 2004.
  1. garymeg
    garymeg
    I am connecting my DVD player and freeview box through my surround sound stereo.
    I have got it all working but 1 thing.
    The TV Defaults to analogue tv when switched on now.
    This never happened when freeview was connected directly to the tv.
    the s/s amp also switches video aswell as audio.
    :lease:
    Q. what pins do i nead to connect/short in the scart plug to get the tv to think it is still connected with a scart lead ie. power on to the AV channel?
  2. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    You have to put +12V on Pin 8 (9V block battery may also work). 6V would force the TV to 16:9 mode. For switching to RGB input 1-5V is required.
    At your own risk though. :)
  3. AMc
    AMc
    Nov 20, 2000
    6,948
    Near Norwich
    +3,552
    How have you connected your sources to your amp and TV?
    I haven't seen a SCART switching amp so I presume you're using composite video (yellow phono plug) and stereo audio (red and white phono plugs) or S-Video (Round multipin connector) and stereo audio (red and white phono plugs).
    To get the TV to switch to a signal on the SCART input you need to connect a source that sends the correct voltage (see above) when it's on.
    I connect my sources using SCART and then use the audio outputs to send stereo signals to the amp. The digital audio signals (DVD and PS2) are connected directly to the amp.
  4. garymeg
    garymeg
    Useing Yellow/ red/ white connectors. the amp has all 3 on aswell
    what i want is to use only 1 remote. ie let the amp switch the source
    at the mo i have to use 3 remotes to to change the source(TV), 1 for the amp and 1 for the source(DVD etc)
  5. AMc
    AMc
    Nov 20, 2000
    6,948
    Near Norwich
    +3,552
    That will be giving you the worst video quality and won't allow you to automatically switch your TV to the SCART input.
    If you're TV has 2 SCARTs and audio outputs then connecting the video sources direct to the TV over SCART and then the audio from the TV to the amp will give you better quality video and the audio will 'follow' the source you've chosen on the TV without adjusting the source on the amp.
    Alternatively use the audio outputs on your Freeview box into the amp and the SCART output to the TV and the digital output of your DVD player into the amp and SCART output to the TV. If you connected the analogue audio output from the TV/Freeview to the analogue sockets for the 'DVD' source on the amp and the digital output from the DVD plater to the digital socket for the 'DVD; source on the amp then when you turn on the DVD player it should over ride the analogue input and give you true surround sound. If the DVD player is off the amp will revert to the analogue inputs and give your Stereo sound.
  6. garymeg
    garymeg
    My setup is as follows
    TV
    1 comp/Audio L/R in
    1 comp/Audio L/R out
    1 Scart
    DVD
    1 Scart
    1 Comp/Audio L/R out
    1 Digital audio optical
    1 Digital Audio Phono
    1 S-Video
    Freeview
    2 SCART
    1 Audio L/R out
    Freeview don't output S/Sound on scart 2
    Amp Has no digital audio in
    Freeview and DVD both output S/Sound
    Will TV output S/Sound on audio outs if input from SCART is S/S?
    is freeview scart a passthrough if i connect dvd scart to freeview scart2?
    would this override freeview when dvd switched on or would i have to switch off freeview?
    DVD is Hitachi DV-P315
    TV Old BUSH Stereo model unknown
    Freeview if old Phillips ITV Digital box
  7. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    DVD>FV>TV (via scart) and the audio out to AMP........
    assuming TV scart excepts RGB set DVD and FV box to RGB outputs for a better Picture...
  8. garymeg
    garymeg
    So the audio outs are connected directly to the Scart audio in?
  9. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    audio outs (ON TV) connected to AMP for sound...
