scart -> 3 phono
Discussion in 'Cables & Switches' started by jasper_mccrea, Sep 2, 2005.
  1. jasper_mccrea
    jasper_mccrea
    Dec 5, 2002
    902
    28
    London
    +25
    I'm curretnly using the worst cheapest scart -> 3 phono (composite and two audio) from my tivo to my amp, and I'm sure it's not great, not least because I soldereed it up myself. Is there anywhere I can get a semi decent one of these, £20 or so? I had a brief look, and the only ones I foudn were switchable direction ones, which I don't think I want.
    Cheers,
    Jasper
  2. bobbypunk
    bobbypunk
    qed sqart av1420 2m scart to 3 phono probably more than £20 but well worth it.
  3. rdhir
    rdhir
    Jul 31, 2005
    471
    Glasgow
    +8
    If its from TIVO don't forget the audio outputs work fine. If you're TV has an RGB option turn it on - its fab.
    Rajiv
