scarey movie
Discussion in 'Movie Forum' started by Mark P, Jan 28, 2001.
  1. Mark P
    Mark P
    anyone else had a problem with this region 1 disk. as soon as the film finishes and the credits start to roll, the film pauses.
  2. Ace007
    Ace007
    Scary Movie was fine on my Pioneer 737, what player do you have?
    Ace
  3. Mark P
    Mark P
    got a toshiba sd3107b, got over 25 region 1 disks and they all play fine. it just means i have to pick up my controller and fast foward the frame when i want to watch the hilarious Grab and Run scene at the end. im sure i can live with it, i was just curious to see if anyone else had the same problem, take care ace.
    mark.
  4. Mark P
    Mark P
    mark.
  5. ptmbradley
    ptmbradley
    Aug 15, 2000
    253
    Body in Wolves, heart in Cardiff!
  6. Canary
    Canary
    Yes, I've had the same problem on my Sony DVPS536. It may be that the film is so bad that the player can't wait to get it over with!
  7. Cortex
    Cortex
    My pioneer 515 and my pioneer 114 (PC) both play this movie without any probs. But who cares! It's at the end of the film!
