Scanned Doc. to CD/DVD?
Discussion in 'General Chat' started by GJC, Oct 20, 2005.
  1. GJC
    GJC
    Mar 1, 2002
    2,145
    London
    +69
    I'm researching various ways of transfering documents to CD/DVD. I need software and or hardware that will do this and allow me to search the contents of the scanned Document (preferably pdf) within the DVD.
    E.G. The DVD will autorun, Page 1 will refer to page one on DVD and if possible the contents table of the document will be linked in the DVD so that the user can click the chapter and be taken to it.
    Any ideas?
    Thanks!
  2. SanPedro
    SanPedro
    Jan 11, 2001
    4,548
    +534
    You mentioned scanned documents and PDFs
    Are you talking about scanned images within a PDF document, or converting, say, a Word file to PDF. There is nothing in a bitmapped image to search on, apart from any meta data you embed within the file somehow.
    I believe the files would have to contain actual text in order for them to be searchable/indexable.
    Chris
  3. GJC
    GJC
    Mar 1, 2002
    2,145
    London
    +69
    Thanks for the reply Chris.
    Basically I want to scan 'a book' containing upto 1000 pages or for example then transfer the scanned images in order to create a published CD or DVD, it would effectively become an e-book/digital bible.
    Cheers!
  4. tomson
    tomson
    Jul 19, 2000
    1,959
    Berk'amsted
    +186
    have worked on branding documents where we've designed a printed version then transfered everything into an html version. All the content is displayed within a browser and has a full index and search facility. This can be put online or onto CD. Have also done similar using PDFs for distribution on CD - save out each page as a PDF then combine it all into a single document that's viewable in Acrobat. You can create thumbnail and text indexes and retain full search functionality.
  5. shahedz
    shahedz
    Apr 26, 2005
    11,118
    +2,045
    HI check these guys out www.pinpointdigital.co.uk they specialise in scannign and archiving and i think they can do what you need,
  6. GJC
    GJC
    Mar 1, 2002
    2,145
    London
    +69
    Thanks for the info guys I'll read up on the info you've provided. :smashin:
  7. SanPedro
    SanPedro
    Jan 11, 2001
    4,548
    +534
    Tomson, that'll work for text based documents, but not PDFs that contain scanned images - you can't search through images as you would a Word or text based PDF - (assuming that's what's needed) - in order to find a word or phrase within a page.
    Also PDF files, unlike .exe files will not (easily) be made to autostart from a CD. I did find this though http://www.cdmenupro.com/pdf_starter.htm that might do the job.
    A lot of document management systems for scanned images rely on using a database application that assigns searchable keywords to the images. You could try doing a Google on document management solutions (or similar)
    Chris
  8. tomson
    tomson
    Jul 19, 2000
    1,959
    Berk'amsted
    +186
    Indeed. From GJCs 'book' description I presumed the content would would be predominantly text based anyway.
    But if you ensure every image has a description (much like meta tags , but visible) you can build up a fairly intuitive search facility that pulls up image descriptions in the results . Obviously it requires a fair bit of forward planning.
  9. GJC
    GJC
    Mar 1, 2002
    2,145
    London
    +69
    The documents will be 95% text based, the images dont require data for search purposes.
  10. SanPedro
    SanPedro
    Jan 11, 2001
    4,548
    +534
    I took it that you were scanning a book and creating bmap images of the pages. I couldn't see how a scanned book could be text based. Unless you're using OCR software on the pages afterwards. Or have I missed something here?
    Only trying to helpfull on the details given :)
  11. GJC
    GJC
    Mar 1, 2002
    2,145
    London
    +69
    Apologies should have been more specific. I believe OCR software would be needed so that keywords can be searched?
  12. tomson
    tomson
    Jul 19, 2000
    1,959
    Berk'amsted
    +186
    Absolutely. Again, I assumed this was a given. Should have explained that.
    Mental note to self: must stop assuming.
  13. SanPedro
    SanPedro
    Jan 11, 2001
    4,548
    +534
    There was a great quote in a film I saw once
    "Assumption is the mother of a **** ups"
    Just so true. After nearly 20 years in design I (try) not to assume anything of my clients and suppliers.
    :hiya:
