scan doc by pressing scan button
Discussion in 'Computer Peripherals & Consumables' started by leecavturbo, Jan 8, 2012.
  1. leecavturbo
    leecavturbo
    Apr 24, 2009
    979
    28
    +26
    apparently my printer/scanner epson sx435 will scan a document when i press the scan button and send it over the wireless network.
    i cannot get it to work.
    i can print wirelessly to it and scan wirelessly from it but only by telling it to scan from my pc.
    you should beable to do it at the scanner.
    from what i have read epson event manager is the key.
    its installed and sees my printer however it should have a notification in the clock area taskbar indicating the program is running but no icon is visible. i have checked its not auto hidden.
    anyone sorted it?
    os xp
