Scan Converters?
Discussion in 'Desktop & Laptop Computers Forum' started by jameson_uk, Apr 4, 2005.
  1. jameson_uk
    jameson_uk
    Dec 9, 2004
    3,707
    Birmingham
    +579
    I have a Radeon 9200 and plugged everything in via a VGA => RGB scart cable but whilst the PQ was great in general, there was something wrong with the refresh rate and this makes it unusable on my TV. I have tried about 10k setting in powerstrip and now have to admit defeat that my TV (old 4:3 29" Sony CRT) is not up to the job. I can't afford a plasma or LCS screen :( but I am not happy with the quality of the S-Video connection.
    I was therefore considering two options:
    1 - Getting a scan converter. This seems to be about £180 and do the conversion between VGA and RGBS and has RGB Scart option. (I was looking ar the Corioscan CS-320 Connect)
    2 - Getting an x-card for RGB output to TV of MPEG files and then getting a tiny monitor to act as control for the rest of HTPC. I have seen a 7" touchscreen for about £180 which looks like it would do the job.
    As for (1) I have been told I can get one on a 7 day sale or return basis so I guess I have nothing to loose in trying it. With (2) I guess I loose the ability to output my shared pics on the TV (on of my reasons for having HTPC) so not ideal but if PQ is signigicantly improved then I suppose it would do.
    Any comments / experiences of scan converters ??
  2. JonMace
    JonMace
    Nov 20, 2002
    2,567
    83
    Kent
    +210
    Can't understand why you would want to spend £180 on getting a old 4:3 screen working it would not take a lot more cash to get a cheaper make WS 28" that should work with your system, worth looking onto anyway.
  3. jameson_uk
    jameson_uk
    Dec 9, 2004
    3,707
    Birmingham
    +579
    When I had a DVD or cable box via RGB the actual PQ of the screen was great.
    Also a 28" 16:9 screen is a lot smaller than the current screen and I would not really want to go much smaller. If my maths is right, to get the same size 4:3 picture I would actually need a 35" 16:9 TV.
    I only really have max £250 to play with so a new TV is not an option
  4. JonMace
    JonMace
    Nov 20, 2002
    2,567
    83
    Kent
    +210
    It depends on if you are watching WS (a lot of TV is broadcast that way now and in the end it will all be). Your 4:3 27" has more area than a 28" WS but not veiwable area in WS
  5. JonMace
    JonMace
    Nov 20, 2002
    2,567
    83
    Kent
    +210
    I've been sitting trying to work out suare roots (stupidly) and just remembered the shere facts the size of a TV is the diaganale therefore by going to a 28" WS form a 27" 3:4 you will get a longer but shorter TV. It will give you a better and BIGGER picture the only time this is different can be with PJ screens
  6. SeanT
    SeanT
    Jan 28, 2005
    6,163
    Coventry
    +368
    Not true, the further you go from a square image the less screen area (and therefore size) you get for a given diagonal.
    In the example you have used, the 28 inch widescreen has an area of 335 sq inches, and the 27 inch 4:3 350 :oops:
    P.S. a 27 inch square grows to 365, and a 27 inch widescreen would be only 311! - ergo, more than happy with my 26 inch 15:9 set once it is setup and scaled properly - you are right about everyone going widescreen though as it is more watchable :)
  7. MikeFish
    MikeFish
    He actually said his old TV was 29" not 27".
  8. jameson_uk
    jameson_uk
    Dec 9, 2004
    3,707
    Birmingham
    +579
    Yeah spent a while trying to figure it out but I think a 29" 4:3 which is what I have has 403 sq inches which is about 20% more screen area that a 28" WS set (the actual true dimensions are all going to be less this is about right)
    Point taken about most stuff being in WS though as I guess I loose a load of the screen anyway. I have just sat down and worked it out I think :confused: and I reckon @ 16:9 my actual picture size would be 302 sq inches so yes a 28" WS set would actual give me a bigger picture for WS stuff.
    This however does not address the issue that I only have max £250 to spend and in order to even get a 28" WS TV with as good PQ as my current TV, I am going to have to spend more than this.
    :lease: anyone actually got a respone to the original question :lease:
  9. JonMace
    JonMace
    Nov 20, 2002
    2,567
    83
    Kent
    +210
    Sorry that what I was trying to say in my round about way
