Scaling question Pioneer XDE/HDE/FDE
Discussion in 'Plasma TVs Forum' started by Lizzard, Dec 23, 2004.
  1. Lizzard
    Lizzard
    If you send a 1280x720p/50 signal to the Pioneer mediareceiver thru HDMI, will the mediareceiver scale the signal to the panels native resolution of 1024x768/1280x768 or will it show it as 1280x720?
  2. loonatic
    loonatic
    Jan 4, 2003
    1,925
    41
    Springwell Village, Gateshead
    +16
    It will scale it to the native resolution of the panel.
    Cheers, Lee
  3. Lizzard
    Lizzard
    So it is a better plasma to buy if you aren't intending to buy the 43/50MXE1 and a separate scaler to go with it?
  4. loonatic
    loonatic
    Jan 4, 2003
    1,925
    41
    +16
    It's never as straightforward as that…but I would say that the MXE1 really does benefit from the use of an external scaler and is ideally equipped to do so.
    If the majority of your viewing will be DVDs via a decent HDMI player then the XDE/HDE/FDE will perform very well…but Sky/Freeview will never look as good as it could. You should be okay for SkyHD when it appears though.
    Cheers, Lee
  5. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    You'll be OK for skyHD as long as you either are prepared to stump up for an HDMI switching AV amp, currently £3-4k or unplug the dvd and plug in sky on the back of the media box. But then there are currently no better options for HDMI, it's crap whichever way you turn.
  6. Lizzard
    Lizzard
    The American models got two HDMI inputs, how come they skimped to one input on the Euro model?
  7. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    I know, usual euro 2nd rate goods and all that.
  8. loonatic
    loonatic
    Jan 4, 2003
    1,925
    41
    +16
    What about a standalone HDMI switcher like those from Gefen and others ?
    Cheers, Lee
  9. Lizzard
    Lizzard
    Another question is that i often experience that the Pioneer XDE/FDE/HDE models are always more soft or can you say out of focus than other plasma panels.
    Is that because Pioneer replaced one layer with plastic film instead of glas?
